Full Set keys and locks - Overseas version?
Hico, Texas
After thieve ravaged my 1991 80 I'm looking for a full lock set and this is currently on Ebay: Toyota Land Cruiser FJ80 FZJ80 HZJ80 OEM Ignition Cylinder Door Lock Keys SET | eBay - https://www.ebay.com/itm/353220789720
PN: 69005-60340
The last thing I want to do is spend this much money and it not work. Any used this PN with USA 80's?
The first one replied that I need the 69005-60330 version but they don't have any.
ALL THOSE ARE NON_USA variants
THEY WILL NOT work or fit on a USA Spec. 80 series of ANY Kind .
don't get taken my friend
sorry , jsut straight talk
i have studied this topic well , and well .............KNOW what im talking about 100% here
matt
I've read a few posts that I think they used some overseas versions...but had the rear lock for the ambulance doors instead of our clamshells. I'd love to know as I need some...
PN: 69005-60340
The rear hatch is a different lock set up all together
the Ignition is the same and so are the 2 front side doors , just like @Delta VS has quite nicley Laid out in his shop online store he has going on ......
i am unsure about the whole glove box lock topic my self ?
i have only re-keyed 1 80 series ignition in my life and if i can it will be the last ..........
that Jazz was HARD as hell to do and a necessary HACK type job i am not used to .....
drilling out Dowel pins and having to use CRYPTINITE JB weld ?
grinding off factory PEENED over male rivet heads with a waffle pattern on them
screw that 😆
Damn, looks like they drilled it? Basically you're in for a whole new set of locks and keys. I'm not an expert on landcruiser key sets, but I know my way around the parts catalogs. There are only two parts in the US catalogue for key sets, one for the 80 series landcruisers and one for the LX450's with the laser cut keys, which I won't cover. The key set is just a bunch of keyed alike barrels with a set of keys to cover them all. You can also order the individual barrels keyed differently with their own key sets.
Here's the part numbers for a US spec 80 series:
69005-60330 - CYLINDER SET, LOCK
69057-60030 - CYLINDER & KEY SET, IGNITION SWITCH LOCK
69052-60050 - CYLINDER & KEY SET, DOOR LOCK, LH
69051-60050 - CYLINDER & KEY SET, DOOR LOCK, RH
69056-60020 - CYLINDER & KEY SET, GLOVE COMPARTMENT LOCK
69055-60040 - CYLINDER & KEY SET, BACK DOOR LOCK
Unfortunately the complete set is NLA. You could order them individually (except the back door lock which is NLA), but that sucks a little bit, because then you have to re-key everything. There are more regions than the US though. When you look in the general region, there are actually 12 different part numbers for the key sets for various different arrangements. All of those are now NLA, with the exception of the 69005-60340 part as you've found. You're in luck though, because the only difference between the original 69005-60330 key set you're after, and the 69005-60340 key set which is available, is the fact that the latter covers the swing-out door style (ambulance doors), as opposed to the lift-up back your 80 will be fitted with. You can verify this, because the vehicle models which select the available 69005-60340 part use the same part numbers for the individual cylinder & key sets as the US spec 80 series.
What do you do then? Buy the 69005-60340 key set while it's available. Remove your current lift-up back key barrel and get it re-keyed to match. That's what I'd do anyway.
Hello , Mr DELTA ,
can you Re-Key a FJ62 Glove Box Lock cylinder by chance ?
are you familiar with what i refer to ?
I have not, I do have a broke down 60 in the yard, I will take a look at that one. I imagine they are pretty similar to a 62?
And yes, rekeying the ignition seems like it's not worth it, which is why I key the door locks (and glovebox/hatch if desired) to the ignition.
These turds did a number on my steering column/ignition....probably my biggest problem.
So you just need a new ignition barrel and have it rekeyed to match your doors ?
I probably have a few barrels kicking around and will have a set of locks in the next few weeks as I am pulling the FJZ80 Stuff and replacing it with the HDJ80 as the HDJ80 has much better key strength then the FJZ80 .
As @ToyotaMatt mentioned, rekeying the ignition is a pretty big pain, would be much better off getting a new ignition with new key and rekeying everything else to that.
i should clarify
fj60 did not come with a locking glove but fj62 did
you can simply swap them back and forth same glove box metal door
so ......
can you re-key a 62 glove box lock / twist dial knob on a usa spec. FJ62
thanks
i should clarify
so ......
thanks
Should be able to, can you post a few close up pics?
