I've done about as much as I can as far as eliminating drag points so I was thinking about making a full belly skid plate out of 1/4" aluminum that would be mounted at the points marked below and bent like the red line at the top of the picture (side view of pan).
The mounting brackets would be made of steel bent in a "U" shape with nuts weld into the bottom. These would be bolted to the radius arm rear bolts and the front of the bottom rear control arms then the pan could be bolted to these and the threaded holes in the cross member. I imagine a couple of 4" access holes in the pan also.
What do you guys think about this idea (overkill, waste of time, good idea)? And what problems do you think I would run into (heat, access,etc.)?
Thanks for your input.
