Klooge in an diode electrical fuel pump $10 - see if it draws fuel.
Maybe the float/needle valve is stuck - wack the carb with mallet and see if flows.
Could be crap in tank(s) is blocking pick up - use like 5 psi air into the line to blow the crap free - listen for air bubbles at the gas caps. Add some yellow bottle gas dryer to the tanks - paper elements in fuel filter will not pass fuel if wet from water - warm days cool nights will condense water right out of the air into you gas tank as well as the station selling fuel. Set used filter in the sun for a few days it will dry out and be good as new. I cycle threw like 3 of them.
Does your carb have a electric cut off? - yes check the connection.
This my fuel transfer pump - switched fused filtered 5' draft 20' delivery with like 12' of power cord that will fit the battery or cig lighter was like $50 of parts from Amoron and ebuy. I use it to move fuel from 5 gal cans to rigs. If you switch hoses you can drain fuel tanks making them easier to drop for cleaning out crud.
