I have a 91 that I'm working on a friend told me I didn't have to replace the fuel sock just take it off and not use one cause gas in the U.S. is clean and the 91 already has a filter. just need some other input. thanks
Thanks, order a new one from napa and on a side note the friend is a master technician from the local chev.dealership.
Follow this thread:https://forum.ih8mud.com/80-series-tech/737901-how-fuel-pump-install-plus-upgrade.html
Here is exactly why you need to change the sock:
Kick your friend in the nuts the next time he tries to tell you anything about your 80
I don't think it needs to be replaced as PM, but if it's damaged/broken, then you should put in a new one. Debris can get in there from other sources like gas cans. Someone on MUD had numerous clogs after a refurbished Nato gas can that had been painted on the inside had all the paint get stripped by the gas and the paint chips/flakes wound up in the tank plugging his system badly.
NLXTACY thanks for the thread one question why can't you reuse the banjo fitting?
Sorry why can't you use the crush washers? air/leaks?
