Hallo Mates:
question on the Fuel Separator - that sits inside the rear pass wheel well in front of fuel filler neck
I just replaced the fuel connector 77209.60040 - this piece bolts to bottom of inner rear wheel well - has 5 nipples for fuel lines
OK - the one I replaced was rusty - was able to match all the fuel lines EXCEPT to line from top of Separator - the single line comes off the top - near top mounting bolts - split in line is a plastic valve WHITE - looks like a vacuum dashpot - - plugs into a single nipple - not in line with any of the others - sort of above the lines that plug into the fuel tank lines -
the one I replaced - this nipple on the underside / exposed to underbelly of truck - broke off -
dunno where it should connect to outside - as to the inside nipple attaches to this single line /valve to top of separator
Anyone have any ideas?
cheers:
cheers:
