Fuel Return Line / Hose Type
Lonely Nevada
Website
www.willenosphotography.com
Replacing all vacuum.. coolant and fuel return hoses. Just about wrapped up.. but now in a quandary. For the fuel return lines can you use an SAE 30R7 50psi hose? Or do you need to go the same as the high pressure line? Confused since the return fuel psi is close to the hose rating even tho burst rating is 250psi. Also read on the Gates website that SAE 30R7 is not recommend for return lines for vehicles newer than 1985 due to permeating vapors thru the hose body. If it was for the high pressure line it would be a no brainer.. OEM with fittings!
Since 30R9 seems to be hard to find by the foot in my local I want to find out if I am capable of using Gates SAE 30R7 or do I need to get the 30R9 or equivalent? Only want to do this once as I really don't like surprise fuel leaks!
I have searched MUD 80 series and came away with no info regarding the type of fuel hose to use for a return line. I have plenty of Gates 50psi SAE 30R7 that I am in hopes I can use since the return pressure is not that high. Would have just gone ahead and picked up some high pressure 30R9 and called it good.. even tho' the rating was way more than needed. But trying to find 1/4" / 6mm high pressure hose is a bit of problem. As a default I will have to order some if I can't establish that 50psi fuel line is NOT okay.
