fuel pump?
Conejo valley
My 55 is definitely being a pig. As I cruz around town at low torquey rpms it has been coughing. It is like a back fire. It is kind of like when I am supper low on fuel. I replace the filter and still it backfires. It is random. Now at the stop light the engine will just die if I don't press on the gas a little.
Any guesses!:confused:
fuel pump is mechanical, so it either works or it doesn't. Probably fuel mixture at the carb.
check your fuel filter. Have you gotten gas somewhere new?
or a vacuum leak
There's a little porthole window in the front of your carburetor and it's there for a reason. Clean it off and look through as the engine tries to run or die. If the fuel level stays in the middle of the porthole, it's not a fuel delivery issue.
pooooooeeeyyyyyyy
looks like there is no compression in the third cylinder:o:mad::mad:. Looks like I am doing the wrong thing when I put that thing together:crybaby:! I think that I have milled it too many times. Maybe it's a crack. Anyone got a head for a 2f :confused:?
it would not fix the problem you are having.....how do you know the is lo/no comp in #3?And adjust the valves.x3
