- Joined
- Dec 30, 2008
- Threads
- 16
- Messages
- 85
The 80 started acting up a couple weeks ago and I finally got time over the weekend to get her running right. Here is the step by step (Mostly) on troubleshooting and correcting the problem that turned out to be a bad fuel pump.
The Truck:
91 FJ80
3FE motor stock
235K miles
The Problem:
The truck has been hard to start for a couple of months (Takes 2-3 tries to start, fires then dies) but wasn't that big a deal. Driving home one night she was very low on power and would not accelerate. If I put her in neutral she would rev-out but then bog down when put back in gear. Starting now became very difficult, you had to feather the gas peddle like you were starting a carbureted car that had been sitting for years. The idle was also a little rough.
Troubleshooting:
I started by checking the Throttle Position Sensor. The FSM covers this well and there are a bunch of posts on the TPS so I'll skip the details. The TPS tested fine.
Next I check the Air Flow Meter. The FSM covers this well and there are a bunch of posts on the AFM so I'll skip the details.
I decided to check for fuel next. I removed the output line from the fuel filter (located on the frame rail under the passengers feet) and jumped FP to B+ on the test block on the passenger side of the fire wall. When the key was turned to the run position fuel flowed through the filter.
I had fuel flow but now need to see if I have enough pressure. I went to O'Reilly's and borrowed a fuel pressure test kit #67091 ($110 deposit). This kit had the correct fittings to interface to the Land Crusher.
Pictures coming up next.
The Truck:
91 FJ80
3FE motor stock
235K miles
The Problem:
Troubleshooting:
