Fuel pump troubles....
Oregon
Did you ever just want to blow your Cruiser up? Probably just me... Well, my 55 has a 292 Chevy inline 6 in it, with a Rochester Monojet carb.. I started having problems today with it running then dying... I would let it sit then it would start again after a bit only to do the same thing a few minutes later, sometimes seconds later.. Sometimes it would sit and idle, but just die when you tried to give it gas, and eventually die sitting there idling. The plugs look good and Im getting a spark.. The timing has been tweaked all day long and hasnt helped, as well as the mixture on the carb.... At first I thought it was the points since they didnt look that good, and replaced them. Still did it.. So, I checked the fuel filter, and found a pile of debri in the bottom of the glass jar. I replaced the fuel filter with the inline plastic type, and the problems still persisted. Next I thought maybe the gas tank had some debri clogging it, but when the gas line was removed from the filter, gas came rushing out like crazy.. So, I then thought it was the fuel pump and went and bought an electric fuel pump (that my friend convinced me to buy) and installed it, but now when I turn the fuel pump on, a stream of gas shoots out of a small hole in the top of the carb (which by the way dosnt look like anything goes into, but rather a vacuum port thing in the mouth of the carb).. Im having a very, very frustrating day.. :frown: :frown: Do monojets just NOT work with an electric fuel pumps?? The cruiser has ran fine for over a week, since I bought it...??? Any ideas are much appreciated...
anyone?
Do I need to go back to the manual pump?? Is there a better carb for my application? I dont have the money to go out and buy some 300 dollar carb at this point, so I'd like to work with what I have or figure out a cheap plan (already dumped a chunk into this thing).. Is there something toast in my carb, where the gas is squirting out, or do monojets just plain not work with electric fuel filters?
Boy... My other 55 with the stock motor and all, sure is alot less of a headache... Although it dos'nt have near the power..
Land Bruiser said:
So, I then thought it was the fuel pump and went and bought an electric fuel pump (that my friend convinced me to buy) and installed it, but now when I turn the fuel pump on, a stream of gas shoots out of a small hole in the top of the carb ? Any ideas are much appreciated...
Sounds like gas coming out of the bowl vent, which is usually an angled brass tube in the top cover. If so, this is an indication that either the needle valve or seat is bad or dirty or the float is bad. Take the top cover off, clean or replace the nedle valve, check the float to make sure it floats and see if the problem goes away.
Thanks Pinhead... I will try some of the things you are suggesting... I wish I could find more information on this damn Carb!! Wanted to go through it, but... Been up and down the internet for days on end, and have found nothing.. At least Holley has technical documents all over the web.. Surprising, being Chevy and all.. I've been thinking of going and trying to find a chilton or Haynes manual for a 70 something pickup truck with the same motor and hopefully carb (looked up block numbers and got 64-76.. Nice broad range.. **sigh** I'm guessing its a later version...
Well, I have spent all day messing with this carb... And no luck... I checked the float and needle valve, and everything seems to be working correctly... Its almost like the electric fuel pump is pushing it open and filling the float bowl up... Its rated at 4 to 5.5 psi, which should work.. Any Ideas?
Your descriptions of the problem are a little vague and ambiguous to offer much of a useful response, but if gas is coming out of the bowl vent tube (usually about 3/16 diameter, brass tube with the end cut off at an angle), the needle valve and float aren't doing their job. If the pump is really putting out only 4-5 PSI I doubt that it would be enough pressure to defeat a properly functioning needle valve.
So how do you know it the needle valve and float are working?
The nice thing about Rochester 1bbls is you can walk into any parts store and get a rebuilt one for cheap. I'm not sure that is the problem, but in the absence of a more detailed analysis, the trial and error method might work.
