Fuel Pump Relay; Why so Much ???
Canyon Lake, TX
I had to change out my fuel pump this week and figured I should replace the Fuel pump Relay for good measure. When I talked to CDan, he said it would be $70 for the part. I looked on line and only found the fuel pump relay Assembly.
Help me out here, it seems that I could simply replace the relay only with another relay. Am I asking for the wrong part, or must I buy the entire Assembly?
Thanks for your time.
IF Dan said it's $70 for the assembly and you want to run OEM parts, that's what you're going to pay. That doesn't sound too bad for something that will last another 150k.
I found the same relay in a Previa supercharged van at a pick n pull
When you look at the relay here:
https://forum.ih8mud.com/80-series-tech/162072-fuel-pump-relay-cleaning.html
It looks like a regular old relay. Just like the ones which are rated by amps. i.e. 15 amp, 30 amp ...ect. Which cost around $15 - 20. I don't quite see how a relay "assembly" is needed to replace the relay only. This is why I am wondering if I am asking for the wrong part so that I simply replace the relay itself. I had to replace the headlight relay once and I don't remember Mr. T getting something close to $70 out of me when I bought it from Dan.
Times like this are when I really miss that DIY site with all the Toyota parts list WITH pictures. :frown:
You can bring up diagrams here Auto Parts People But no part numbers. These prices are comparable to Dan's but you're on your own and the service isn't great.
