I am seting up an '86 pickup that sat for a few years before I got it. Had everything running good after tune up and freshening up some leades and grounds.
Here's my problem: my wife took it to the gas station and it quit. We found out it wasn't getting fuel. I replaced the fuel filter, didn't help. I then took out the fuel pump and tested it. The fuel pump worked fine. We figured out that she kicked off the fuel/EFI main relay and it was rolling around on the floor
. After plugging it back in it ran fine for one day.
I took it to the store today and it quit. We towed it home and found out it has no fuel again! I yanked up the fuel pump and here's the weird thing... It pumps with the key on and the truck starts up as long as I am holding it so the pump is towards the top of the tank, not touching anything. If any of the tubage or the pump touches the tank it quits pumping and dies. When I put it back down into the tank where it should be it also quits pumping and dies.
Here's another thing: the truck is throwing a two flash code which on an '86 is an airflow meter code! What the heck??
Could the fuel pump be shorting out on a baffle inside the tank when I put it back into the tank? Do they only work if they are suspended in there not touching anything?
Should I suspect the relay that got knocked out?
Am I missing something?
I'm really confused because the trouble is intermittent and we had it running the day before.
Any advice on this issue is greatly appreciated!
Three beers to the guy who figures this out!!
. After plugging it back in it ran fine for one day. I took it to the store today and it quit. We towed it home and found out it has no fuel again! I yanked up the fuel pump and here's the weird thing... It pumps with the key on and the truck starts up as long as I am holding it so the pump is towards the top of the tank, not touching anything. If any of the tubage or the pump touches the tank it quits pumping and dies. When I put it back down into the tank where it should be it also quits pumping and dies.
so now I can finish my suspension, exhaust and flatbed.
