Fuel pump rebuild
fort smith, arkansas
Hey guys. Yesterday I had the good open and was running my 67/40 and all the sudden fuel started dumping out of the carb, I killed it and also noticed fuel all around the pump. Turns out it was coming out of the week hole. I THINK this means it was flooding past the diaphragm thus sending too much to the carb, making it flood? Tips are appreciated. Anyways there are cheap rebuild kits on eBay. Should I buy one or pay 25 dollars more and get an after market pump from cruiser corps ?
Link to the rebuild kits? I run early pumps that had a hand primer built into them.
Two things on your pump. 1. A bad diaphragm leaking out the weep hole will not create enough pressure to cause a problem in the carburetor. Look for a stuck float or needle valve. 2. Be sure your oil hasn't been diluted with gas causing major engine problems pretty quick.
10-4 on the oil change, I pulled the pump today and have an oil filter on the way. I believe the carb is in need of a rebuild as well, this cruiser sat for several years in a shop collecting dust so the gremlins are crawling out. I found an OEM pump online for not too expensive through fjparts. As for the carb, I’m not sure why both incidents would happen simultaneously, guess it’s just a coincidence.
TOYOTA LAND CRUISER FJ40 FJ45 MECHANICAL FUEL PUMP VALVES WITH DIAPHRAGM SET | eBay.
Here’s a link to a kit, there’s lots from diff vendors in Indonesia. Takes forever and a day to ship.
Thanks for the link. Miss the days when Toyota sold rebuild kits cheap. I remember brake/clutch/fuel pump kit under $10 apiece. Think I'll pass on these kits and continue going thru my stash of fuel pumps for parts as needed.
I was concerned with the material the diaphragm was made from, which is why I broke and paid for a new pump. I may end up ordering one of the kits to rebuild my old OEM as a spare.
Personally I would replace it with a new one, its a simple job and a new pump is about $150
But if the earlier pumps are anything like the pump on my 81...they are not built to be rebuilt. The top is crimped on, not sure how it can be taken apart without damaging it.
The return from your carburetor went to the pump. Originally the carburetor didn't have a return. Then a return to the tank. 1/79 the design changed to sealed with a third line for the return.
my pump is original to the truck, a 67 and it is very much meant to be rebuilt. it is three sections that screw together. Toyota has discontinued the rebuild kits though. also, 150 would be a damn good price from what I can find, send a link please. I got mine for about 180 I think from fjparts. hell, sor wanted like 600 dollars and I don't even think it was new. obviously the complexity of the job wasnt a concern, as I was willing to rebuild if after removal.
I do not believe there is a return, from what I can see. the carb is not Toyota. best i can tell it is a mid 1950's GM Rochester 1bbl. someone got lazy back in the day and swapped it instead of rebuilding the oem.
I have vavle kits for fuel pump part no. 04232-60061. If this is what you are looking for.
are these the two small brass valves? I would need them as well as the diaphragm. I would like to rebuild the one I took off to keep as a spare.
The pump kit is a valve kit, does not have the diaphragm with the spring, only the valve section.
Mine iOS the later pump...OEM is $119:
with spacer $126
with spacer $126
as I stated above my truck is a 67 so this is the wrong pump. he does have my pump though and he still has better prices, wish I had seen his. thanks for the link.
ganna have to stick with fjparts anyways, cityracer is out of stock like everyone else evidently.
Yours would not have a return line. Those didn't start until the early seventies. Those we're all two barrel carburators. Your stock was a one barrel. After many years of aftermarket carburators I went back to a stock one barrel on my 68. For how it's used it the best carburetor I've had.
