I just replaced the fuel pump on my 02/80 FJ40. The old one was leaking but I couldn't tell if it was at the block or from the pump itself. Put the new one on and no more leak - used two gaskets and the insulator. Also seemed to fix that nasty gas odor I always had after driving it. Sweet.
Ok - My svc manual shows a pump that has a removable pump cover. The one I took off which looked old and the new one I got at SOR (they says its OEM) and just installed do not have a removable cover - the whole pump unit looks to be two pieces crimped together in the middle. ANyway, I am curious as to how they wear and ultimately fail. So, here are my questions:
1] Could a clogged return line cause the pump to fail prematurely? Can I blow low pressure air through this line to check or is that a no-no? I am worried that, if the line is clogged, my new pump is going to fail again also.
2] Any other ideas on what causes these to go?
3] If I cut open the old one - what should I look for in terms of failure?
4] Any other ways to check the old one without cutting it open? Again, because its crimped together and not bolted, I don't see anyway to take it apart without cutting.
Appreciate any help and/or thoughts.
Andy
Andy
