I'm going out to the garage to install the fuel pump onto my '75 2F and I'm wondering if I should use any sealer on the gasket? I found that the torque on the bolts to the block should be 13 ft lbs. Thanks.
Note: This feature currently requires accessing the site using the built-in Safari browser.
toyota gasket = good to go
aftermarket = coat it
Make sure you get the right fuel pump also. Some are built a little different and can damage the motor. I forget what the issue is, either the pump arm is too long or something similar. Do a search on this site and I''m sure it will turn up something...
