Fuel pump easy or not?
X2
I would love some info as well
It *sounds* easy - depressurize fuel system by removing the EFI fuse and cranking her for a bit, pull back carpet in the cargo area, unscrew floor panel, disconnect plug and fuel lines, remove fuel pump/sending unit. However, in reality, I'm not sure since I've never done one.
Just pulled mine last week. I did not pull the EFI fuse, had little leakage and reused the same gaskets (I would get new and keep handy in case the originals get damaged).
Follow manual instructions. Pull both rear seats, steps and carpet. This exposes the access plate. Pull the fuel return line and move to side. Unbolt the pressure line (small amount of leakage can be soaked by a paper towel).
Unscrew 8 small bolts holding the plate and pull the assy out. I secured the lines and removed the pressure gaskets to ensure they did not fall into the tank. Simple process.
Suggestion - Do this with the tank close to full as it provides less vapor volume should a spart ignite the fuel. VERY IMPORTANT - HAVE A FIRE EXTINGUISHER VERY CLOSE BY AND ENSURE NO SPARKS OR SMOKING IN THE AREA.
Good luck. Terry
Be sure to ground yourself against the chassis before touching anywhere close to the tank cover. Also, open all doors for better ventilation. Lastly, if it were me, I would not come back with a fire extinguisher if there were an actual fire - I would sure as hell run away as fast as I could.
Be safe!
Frank.
