Fuel Pressure Regulator
Tulsa, OK
I installed a weber 34/34 on my FJ40 with a 2F and am getting a lot of pressure at the fuel inlet. When I remove the fuel line after running the truck for a short time the fuel SHOOTS out.
Would a pressure regulator fix this and what problems could I get by not using one?
Thanks.
Are you experiencing any issues? Why were you disconnecting the fuel line?
My info said you need to run fuel pressure reg for my Weber 38DGAS on my 2F. When I did I had bucking from fuel delivery issues. Removed it and it runs fine.
Post up what issue you are trying to fix. If it ain't broken - why fix it?
AndrewT
Initially the truck ran pretty well... Idled fine, ran strong at higher rpms(but I couldn't drive it so I don't know how it did under a load).
Finally get to drive it and it runs OKAY initially and then starts cutting out on power at all speeds.
Also, it doesn't want to idle smoothly or sometimes at all.-
Electric choke, fuel filters are clean.
Only wants to idle when it is choked.
No vacuum leaks, small exhaust leak that I am unable to isolate.
I took the fuel line off to change the fuel filters and thats when I discovered the serious pressure buildup.
I am replacing the PCV valve today but I don't think thats the issue (needed to be replaced anyway).
I have two fuel filters inline and the fuel inlet has the mesh filter in it, but I don't know why the fuel is building pressure at the carb.
Any ideas?
Thanks.
So the above issues were without a fuel pressure regulator?
Is the carb new or used? And are you running mechanical fuel pump or electric?
AndrewT
Carb was new in box, I have a mechanical fuel pump, and the description I gave was without a pressure regulator.
I haven't bought one yet.... I wanted to get some suggestions first.
Thanks
OK. Let me know how it runs when you replace the PCV valve. I've posted here before that I spent hours tracking back suspected carb issues on my weber only to find a bad PCV valve. Replaced that and all is well. It had the same issues as you: decent idle but stumbles on higher revs and under load. Also make sure the vac line to it is in good condition and secured correctly at both the PCV valve and the intake manifold.
Other items could be cracked distributor cap, intake/vac leak, vac advance, timing, etc..
I'd start by getting a fuel pressure gauge reading from the gas line that goes into the carb. Stock mechanical fuel pump gives you 3-4 PSI. Maybe your weber is one of those that does need a pressure reg.
Do you have all the smog gear on this? Did you replace any other items recently like ignition components, plugs, etc..?
The good news is it doesn't seem like its a carb issue. Carbs run on circuits (idle, progression, power, etc..) and usually one of them has the issue which you can track back based on symptoms. Your issue is different.
AndrewT
Thanks for all the input.
I didn't have time to get the PCV valve tonight, but will update you tomorrow on the progress.
I replaced the plugs, wires, and a few other ignition items but it ran with the new parts fine.
There is no smog stuff on it.
I am assuming I have correctly connected the vacuum advance....
*Silly Question*-are the two flanges on the distributor BOTH vacuum advance, or is one retard and the other advance?
Thanks
Retard and advance in 1978.
The vertical fitting is retard.
The horizontal fitting is advance.
HTH
Post up some info so we can get a status.
If you don't get a new PCV valve, take the old one out and tap it on the floor. The ball inside can get stuck if the rigs been sitting around and that would cause issues. If you blow in it, air should flow out easily but not the other way.
AndrewT
Sorry for the delayed response.
I picked up the PCV valve and realized it was the wrong one, so another has been ordered. I tapped the old one on the ground and still no real difference in idle.
I will update you soon.
I doubt that pressure buildup in your fuel line can account for the problems you described. It seems normal for a carb that lacks a fuel return line and installing a pressure regulator at the carb isn't going to change the situation.
A 34/34 mm carb seems quite small for a 2F as the OEM Aisan has a 38 mm primary bore and a 40 mm secondary. This suggests that its preferred application may be a 4 cyl engine, therefore it may be jetted improperly out of the box. Cutting out under load and bucking and spitting back throught he carb under load are symptoms of lean mixture.
If a 34/34 is too small, why is everyone and their dogs pushing 32/36? for example $or & JTO? lack of power would be a indication of too small, not bucking, spitting that sounds like a fuel delivery problem.
Pinhead-Thanks for the input....
My question is this: JTOutfitters says that the carburetor is specifically tuned and set up for a 2F motor.
Is this inaccurate or perhaps they have modified the jets or something else to work on a 2F?
Also, how do you suggest I remedy the pressure build-up?
Thanks.
The line pressure is from your tank.. on a hot day I can remove my inlet at the carb and there will be a good deal present.. loosen the fuel cap and will stop.. make sure you have the correct cap.. it can also be the cause of poor fuel delivery..
UPDATE-
PCV valve is determined to be okay (I will replace it soon anyhow)
I tried the suggestion of removing the gas cap and then pulling the fuel line to see if pressure had built up..... No luck. The fuel shot out like a geyser still.
Also, does the Weber have fuel cutoff solenoids (I thought it didn't), and if so where are they?
One last thing... PINHEAD-Why wouldn't a pressure regulator remedy the problem? It seems to me that if you lessen the amount of fuel being pushed through it would consequentially lower the pressure building at the carb.
Thanks for all of the ideas so far.
Is this fuel pressure problem just a short blast or a continuous steady hard stream?? It is normal for some fuel ( under pressure) to be trapped between carb and pump.. and yes some webers have a idle solenoid.. what model # do you have??
UPDATE-
Yes, it will lower the pressure after the regulator to whatever the rgulator is set at, but the pressure between the pump and the regulator will be the same.
Low fuel pressure could account for your problem, but I can't see a little pressure at the carb being a problem.
The air fuel mix needs to keep up with engine load, so if it drops too lean, it will no longer ignite by spark, hence the bucking popping and spitting.
If it is cutting out intermittently without regard to the load on the engine, then suspect dirt in your fuel bowl.
Fuel deliver problems usually don't show up as idle problems, so there may be more than 1 thing going on.
So what are the symptoms and circumstances in detail? It might be helpful.
Right now the springs are off of the truck so I can't drive it for a few days but when I was able to drive it, it acted like the stock carburetor did when the fuel filter was clogged. Intermittent power fluctuations, hesitation, didn't idle well. I have two fuel filters and they are both clean. The truck will start right up and as soon as the electric choke goes off it seems to idle rough.
(HOWEVER, now I am having issues with the linkage binding up so I can't determine if the engine is really running at idle speed or if it the linkage is stuck in the wrong position below idle speed)
I only mentioned the pressure building up because it seemed to be VERY backed up. When I remove the fuel line from the fuel inlet I could shoot the gas at least 7 feet (in a short burst).
As far as the solenoid goes, its a weber 34/34 and the only connection on the carb is for the electric choke.
Back-off and revamp.............
