Symptoms were drive for about 20 minutes or up to when vehicle was warmed up, take foot off gas and it would stall and not start for an hour or two. It did this twice over the past 3 weeks. I checked the gas cap to see if there was a vapor lock, no such luck. Today I went to get in it and it would not start which was the first time this has happened. Waited about 15 minutes and fired right up. I do not have alot of history with this truck for I just purchased it a couple months back. Replaced all vacuum lines, plugs, wires, pulled all the electrical connections apart and cleaned, applies electrical connection grease to them all, just preventive maintenance stuff. Noticed for the first time yesterday a buzzing sound out from under the dash which goes off when either the vehicle is started or when the door driver door is closed. Could this intermettin engine stall be contributed to some sort of on-board factory alarm/ disable system?? It never has idled smoothly however does idle around 700rpm without ac on. Last time died with ac on where it usually idles around 1000rpm.
