I'd like to check the fuel pressure on my 94 Land Cruiser, but the way the FSM says to perform this job is by removing the fuel line Banjo bolt from the fuel rail back by the EGR valve.
Then you install a Schrader valve adapter in place of the Banjo bolt so you can connect your fuel pressure tester to that adapter, this whole process is a pain in the ass because of where that Banjo bolt is located.
I'd like to machine my own Schrader valve adapter, that'll sandwich right in between my fuel pressure regulator, and the fuel rail. With the placement of the Schrader valve right up front, it'll make the job of checking my fuel pressure a snap.
Since i haven't had the chance to remove my fuel pressure regulator to check the thread size, I'd like to know if anyone here knows what that thread size is.
