Fuel pick-up keeps clogging
Southern Oregon
I've finally got the '40 running pretty good, and I've found a new problem. I can only make it a couple of miles before the fuel pick-up in the tank plugs, starves the engine and we're sitting on the side of the road looking stupid. I have two filters, one before pump, and one before the carb (327 chev by the way), both are new and not plugged, if I blow backwards on the fuel line it unplugs and I can make it a few more miles. I pulled the sender to inspect the inside of the tank, but there is a baffle preventing me from seeing the pick-up. What is the best way to clean the tank out? I'd take it to a pressure washer, but the baffle is going to prevent me from getting to the problem, and the part of the tank I can see looks good, no debris or bad scaling. I need ideas please.
Thanks!
Next time it happens take off the fuel fill cap. It might be drawing a vacum due to a plugged vent.
I spent a couple of hours in a parking lot trying to figure it out when it happened to me and going and getting the tow bar takeing my fj40 home after I get home I think "Oh the gas cap". This was a common problem before pollution regs in the 70s.
My filler neck has a small hole drilled in it just under the cap, I beleive it is a factory thing, checked that, it def isn't plugged.
There should be a drain plug in the bottom of the tank if it is like my 69. There will be hole thru the floorboards and you can access the drain plug from under the truck. Hope this helps
i had a same problem with my 76 40 (350 V-8) i ended up draining and pulling the tank and filled it with muratic acid and water (about 70% water) but any good rust remover should work. fill the tank as full as you can get it (plug all the hoses ) and let it soak over night, drain and flush several times then use POR15 metal ready in it and then there tank sealer. follow the directions on the sealer can and you should do fine. you have to turn the tank slowly to coat all sides. it works great and you will never have the problem again. good luck!
When you blow back into the tank, are you starting near the carb? Might want to check the connector where the fuel line attaches to the tank next time. I had this problem once. Cracked the line at the tank and found a bee's wing in there!
Next time it happened, found the rest of the bee! All was good after that! ;)
LMAO, wish it could be that easy, all of my lines are new from the tank to the carb, I've had this prob all along, but hoped it would go away when it had more than 16oz of fuel in the tank. I wish the crap would just flush up and get caught in the filter. I'll check at the tank again though.
