Fuel Line Routing
Colorado
OK. I did a search and didn't find anything helpful. I'm installing a '78 FJ40 fuel tank. Is the supply line on the side of the tank or the one on the bottom closer to the driver (#15)? One's the return line, I think. Maybe the pic will help.
TIA
Mike, I knew you had better drawing skills than that! :D In earlier 40s the supply line WAS on the side, no?
Now I also should have asked is if anyone has a set of the hard lines that run along the frame rail they would part with. ;p
In the earlier fuel tanks there was no hard line at the bottom. Only the one on the side. There must have been a pickup inside the tank, or something.
