- Joined
- Oct 21, 2010
- Threads
- 7
- Messages
- 30
This is on a 1997 Fzj80… While chasing down a coolant leak coming from somewhere under the intake manifold, I noticed that a couple of my fuel injectors appear to be wet with gas.
Based on the collective wisdom here, is this most likely due to actual leaking injectors or 24 year old o-rings/seals? I’m not having any typical symptoms of bad injectors (aside from harder starting when the truck is hot). The injectors are $225 each, but is there a chance that I just need to replace the o-rings and seals? Do the injectors themselves typically develop leaks?
thanks for any help here!
