Fuel Gauge
St. Clairsville, OH
My fuel gauge reports "E" all of the time. It never moves. Should I start with changing the fuel sending unit? Any tips, tricks or other things to troubleshoot.
Thanks in Advance,
monkd
Use the forum search. I had the same problem. Now I don't.
The float is stuck. Rip out your back seats, tear up the carpet and unscrew the access port. Then unbolt the sending unit and lift it out. See why float is sticking.
If I recall, there was a connection under the truck I think that I unpluged and cleaned out. That fixed my problem.
Thanks guys. I've searched quit a bit before and after this post and can't seem to come up with anything. I'll use your info and see what I can come up with. Thanks,
monkd
I pulled the sending unit and the float appears to move normally. I've attached a link to a video.
YouTube - Float
The unit looks corroded on the surface of some of the different parts but, it doesn't look too bad. After putting the back in after inspecting it I started my truck and the fuel gauge moved up to ~ 3/4 of a tank. I thought maybe that was actually how much gas I had in the tank. I then went to the gas station to fill up and put about 4 gallons in. After I left the gas station, my fuel gauge went down to empty then slowly (10 minutes or so) back up to about 3/4 full.
I'm not sure what to make of this situation. Any ideas?
monkd
That's odd. Did you happen to notice how much gas was in the tank when you pulled the sending unit?
So did you filled it to the brim after re-install? What did the guage read?
Another thing you can try is pull the sending unit out but don't disconnect the plug. Turn the key to "on". Move the float by hand and watch or have someone watch the fuel guage on the dash. See if it goes up and down as you raise and lower the float. If it does then the float is getting hung up in the tank. If it still doesn't work then that's not your problem.
Yep filled it to the brim after the re-install. Gauge read 3/4 tank. I'll try the manual movement of the float arm.
Thanks,
monkd
gage help
mine is stuck or stays on full,when i got the truck last month i was thinking i get great gas mileage ,and a fill up of 15 gal's i said something is wrong.would this also be the sending unit or gage in dash.
I have a the same problem as rexman. I pulled the float out yesterday and when moving it manually to empty the gauge reads 2/3 full. When the float is disconnected the gauge still reads 1/3 full.
Any ideas?
sounds like an electrical problem
could be the ground in/around the dash cluster... maybe?
start by trouble-shooting the float w/ multimeter but also clean up the plug where it attaches.
