I have an after market fuel tank installed by PO. The fuel gauge barley registers when full. The needle will come up to empty. I don’t see any kind of electrical coming off of the tank to check sending unit. Do you guys have any suggestions?
But wouldn't I be able to see wires coming off of the tank somewhere off of the top. I just don't see any wires coming off of the tank anywhere. But I've been wrong before, just ask my wife. Thanks for the reply.If I am seeing that tank properly the sending unit is probably on the top towards the center front, at least that's where mine is. You may need a new sending unit or the float isn't set properly. Either way the tank would need to be removed to fix the problem. It might be easier to check the wiring connections first though, maybe you'll get off easy.
Look to see if wires go through the tub somewhere. I agree with no wires=no sending unit, at least not hooked up. Do you have a stock tank also, or just the rear tank?But wouldn't I be able to see wires coming off of the tank somewhere off of the top. I just don't see any wires coming off of the tank anywhere. But I've been wrong before, just ask my wife. Thanks for the reply.
Just a rear tank. I thought about a wire going through the tub however it's a1971 and I've been through the interior and don't recall any wire coming through the tub. I'll have to just drop it completely it's just difficult as it won't fit in the garage and I can't leave it over night in the street while I'm working on it. Has to be reassembled and functioning . Pressures on and I'm not a mechanicLook to see if wires go through the tub somewhere. I agree with no wires=no sending unit, at least not hooked up. Do you have a stock tank also, or just the rear tank?
