Fuel gauge adjustment
up there somewhere
The fuel gauge on my '83 40 reads only 3/4 full when the tank is completely full. I replaced the gauge and it still does the same thing. Can the gauge be calibrated with the screw on the side of the gauge?
The gauge seems to move with the fuel level, it just doesn't go to full. Any info is appreciated.
I have the exact same issue on my 77. Always assumed I’d have to adjust the float at the tank but looking forward to hearing the actual fix.
My '77 fuel gauge didn't work right when I got my rig. Installed a new fuel sending unit (83320-60050) and has worked right ever since. I also replaced the tank around the same time due to rust pitting the bottom....That was several years ago.
No calibration required?
@coonassjohn
Sender resistance has to match gauge resistance... I presume ‘83 yo be the same as ‘78. Empty is 120 ohms, full is 17 ohms.
If they are a matched pair, it should measure properly... if the sender is the proper oem sender for your tank, the float arm should be the proper length.
How difficult is it to pull the sender on an ‘83?
Not hard at all. A fuel level unit is nothing more than an ohm meter. All fuel indicators I have worked on require calibration to read properly. As far as I know it is the original sender and the gauge I installed is a OEM.
@Mean One
It’s entirely possible someone replaced the oem sender with an aftermarket sender... or, the wrong oem sender... I both yours and John’s 40s.
‘77 definitely requires 120 empty and 17 full... assuming you have the proper ‘77 gauge.
@Mean One
See the edit to my last post, and no, there is a plate in the rear floor for access to the sender.
Have a new one in the box, I'll give it a try. I thought I read somewhere that that screw adjusted the reading, but not sure.
Rude @bj40green has a “Speedo, clusters and gauges”, or something close. It’s VERY detailed, for every year.
Maybe it will explain that screw... to my knowledge... no.
But I don’t know everything... Rudi does.
Edit: Here’s Rudi’s thread. Clusters, Gauges, Speedo & Odo meters
The PO did replace the tank before I bought it. I will source an oem sender if possible and try to swap.
The sender may be correct. You can remove it and test it, with an ohm meter.
If your ‘77 has a matched pair of oem sender/gauge... but, the tank is different from oem, you may simply need to adjust the length of the float arm, on the sender.
If the sender checks out, as 120 ohms empty and 17 ohms full, you can adjust the float arm, with the use of roll pins (1/8” IIRC)... if you need to lengthen it, a wire coat hanger is perfect in size.
The "screw" on the side of the fuel gauge is the adjustment of the build-in voltage regulator.
Adjustment is done by bending the float arm/lever.
Note: those guages are indicators and not meters.
An accurate indication of EMPTY is more important than Full ihmo.
Rudi
