For as often as the fuel filter needs to be replaced (it is not considered a maintence item. Toyota considers it a repair part, meaning it is replace as required) I think it's in the best place. Remember that the fuel lines associated with it are high pressure. I would not recommend tampering with the factory routing and materials.
After dreading this for a while based on basically hearing so many say it was a MPITA ("M" meaning MAJOR), I was surprised how simple it really was when you slot the tab on the replacement. Seriously, crack the banjo bolts loose first, remove the one bolt on the fender side, just loosen but dont remove the one bolt on the block side, slot that side's tab on the replacement, align the replacement between that bolt, and then thread in the other bolt, torque to spec, then do the banjo bolts and the replacement washers. Easy squeezee, ohh, as Dan already mentioned, it is replaced so infrequently that even if it was much much harder to replace it would prolly be harder to hack out a way to move the thing. JMHO but I hope that hleps.
