fuel door latch?
Conway, SC
Website
www.lowcountrylandcruisers.com
I just installed a new fuel door on my 80! Only problem is with the spring on it it won't stay closed. Is there supposed to be a latch on the body to hold it closed? Mine just has a large nut on the body by the fuel cap... Anybody have a pic of this latch? Thanks!
On my '97's fuel door, it has a rubber ramp - OK, gotta keep this family safe - mounted on it that hits a plunger that is fixed to the body. The release handle you pull inside, I presume, releases the plunger briefly, so the rubber ramp frees to release your door. On a '97...:wrench::hillbilly:
Has your little plunger totally disappeared? That might be the problem. It's not the door, but the thing to hold it closed that's gone missing.
the old door's hinge was broken so it was leaning. I have nothing on the body except a big nut... a steel nut. let's keep this family safe:) Have you got any pics of yours? I am not really sure what I need... thanks
My bet is that your little plunger is no longer with us. He should be located right in the middle of that stainless nut located on the body. Whether that means he's simply gone into hiding or he's completely DOA is still something I don't know. Mine's there.
I'd say you have nothing to lose by carefully loosening up the nut and seeing what happens. If it were me, I'd try to do it over a hard surface where anything that falls out will be easy to find. I had the inside of that quarter panel off the other day for something, but I don't remember exactly what I saw in there except that the wire for the release is routed through there. I tried to look it up in my FSM, but couldn't locate it in a quick page through.
If your plunger ain't popping, I suspect that's why your door's not locking.
what?, no pictures of the little plunger and big nuts?
had similar i would lift fuel gate a little bit than slam. She had a bit of a lean. Not sure if this helps just my .02
Easy fix...replaced my plunger with one from a Tercel.
Bet most models are interchangable.
77037 LOCK SUB-ASSY, FUEL FILLER OPENING LID
77037-12050 FJ80, FZJ80, HDJ81, HZJ81 1 $20.48
