fuel delivery problem, i think
Atascadero, CA
now im not sure aobut this but the fuel is the only thing i can think of. i have a small block 350 wiht the stock 2 barrel and HEI. jsut recently when im dirving it will start to sputter and bakfire. it also .... bucks back and forth. that the only way to describe it. it only does that when its in third gear and about 2000 RPM. i can accelerate fine in first and second but third and fourth are giving me hell. i already tried to clear out the fuel line thinking maybe it was clogged. the filter was clean and it pumps fuel easily. thsi makes me think it might be the carb or maybe not the fuel at all. i checked all or the spark plug wires but they are all fine. i knwo it isnt the air cleaner because that is brand new. any sugestions will help. im losing my mind wiht this.
thanks
-miles
Bucking and spitting back though the carb sounds like running lean. If your pump can deliver a cup of fuel in 15 seconds of cranking, then it is putting out OK.
Lean mixture gets worse under load, like going up hill in high gear.
If your pump is OK, it is time to start considering carb problems.
