fuel cell
Yeah I cant find anywhere that would have extra gas for a return. So I'm just gonna plug it. If fuel starts running out somewhere and needs to go back to the tank then I'll put in a return.
Is that a half-strap welded to the bed such that putting the seat down allows the tank to slide out?
If there is no return line and you are still running a mechanical pump there may be an issue with vapor lock on hot days. Will just have to wait and see. If you later switch to an electric pump then placing a regulator after the pump will allow you to install a return line.
Don't do too much wheeling before putting a gusset on the bed. It WILL eat through the line in time.
Enjoy!
Rice
Yeah when you put the seat down you can remove the tank. Yes I am still running the mechanical pump. I plan on putting in an electric at some point. It would be easy to run a line back to the other outlet if need be.
looks nice bud...
malphrus
