>is since the turbo "uses" the heat that travels through the exhaust,<
>would it actually decrease the temps over a stock setup? Seems too good to be true,<
>what am I missing?<
I only have a few hours education with turbo's many years ago in college but I am quite familiar with their close relative the air cycle machine, and this does not sound accurate to me,
pressure and temperature are directly proportional double one it doubles the other halve one and the other is also halved (in a contained volume), both temperature and pressure are inversely proportional to volume, double the volume the gas is contained in and temperature and pressure are both halved, cut the volume in half and the pressure and temperature double
the turbine operates on pressure differential and gas flow not temperature differential, the drop in temps across the turbine is a side effect of gas no longer being contained and expanding, the heat did not go anywhere or get “used” it is just more spread out, the pressure was “used” and is now lower that is where the energy to turn the compressor came from
I would think your post turbine temps would be the same or higher than a stock truck (forced induction gives higher combustion temps) and probably very similar to supercharged truck, the very high pre turbine temps are more form the gas not being able to expand into a relatively low pressure exhaust manifold and cool like they would in a supercharged or NA truck,
hope that is accurate for a turbo also
