Front wheel play
Colorado Springs, CO
I had the front wheels off this afternoon to check the brakes and put on my 1.25" spacers. When I put the wheel back on the drivers side, I noticed it had significant slop when pulling/pushing on the top and bottom. Kind of clunks - maybe 1/8" play. No play side to side.
I've heard of doing this when checking out a vehicle, but don't exactly remember what it indicates. Bad trunion bearings maybe?
I checked the knuckle studs top and bottom, and they were plenty tight. Passenger side has no play.
Off to seach, but was hoping somebody could chime in.
Thanks!
edit - never mind. Found the front end inspection FAQ: https://forum.ih8mud.com/80-series-tech/137411-front-axle-evaulation-faq.html
Looks like it's the wheel bearings. So, next question. Any idea how much damage is done? I have no idea how long it's been like this - I usually do this kind of test every time I have the wheels off the ground, but that was probably about 7K or 8K miles ago. Front end was repacked by the previous owner of the axles about 20K miles ago.
Should I just tighten it? Or assume I've got damage and give CDan a call tomorrow for bearing & races? How much more damage will I do driving it 200 miles until next weekend?
Should I just tighten it? Or order assume I've got damage and give CDan a call tomorrow for bearing & races? How much more damage will I do driving it 200 miles until next weekend?
You'll have no idea until you tear it open and see what happened. You could open it up and tighten 'em up until next weekend. If the front end was done only 20k ago, and the bearings were in good shape then, they're likely not damaged.
I bought a set of new bearings and races from Mr. Cdan for my next front end job, just so I'd have them in case I needed them. Better to have 'em and not need 'em, then need 'em and not have 'em.
Just retighten them and check again in a little while. They may have seated or pushed out excess grease.....Make sure the washers are smooth and everything.
Howdy! If the play is only up and down, but not side to side, then I think the problem is the trunion bearings. If it was the wheel bearings, the play should show up at any point of rotation. 200 miles will probably not make a big difference at this point, but I would open it all up and ID the actual problem.
Don't just tighten up the bearing preload, unless it really needs it. John
Wheel bearings should always be run with preload, I would tighten and keep an eye on them. Listen for noises and feel the hub after driving to make sure it's not running significantly hotter than the other one.
