Front wheel hub question
Columbia MO
I had front tires put on my '97 today and noticed a little back and forth play in the front hubs. The mechanic said that if I take the little hub nut cap off and don't see any grease my bearing are bad. If I do see grease I can just pull the cotter pin out and snug it down.
So I guess I'm asking if I should just invest in some new bearings, or if I can snug it down, do so and how tight should I make it?
Thanx
Hope these will help...All from the 80 Series FAQs found at the top of the 80s section in the Sticky Threads area :)
Front axle evaulation
Front Axle Rebuild
I'll let the experts answer the question you have but will offer that I think your mechanic is wrong...More than just the hub cap needs to come off to get to the 54MM nut to snug things down. Sounds like at a minimum you need to get in there and tighten the adjusting nut to the recommended preload value. Might as well analyze your front axle before you begin to determine if it is time for a rebuild now and plan for it if necessary.
HTH
:cheers:
Yea, I just took the cap off and guess what? No cotter pin! Hey... he was just some guy at Mr Tires, so I'm not holding anything against him for just trying to answer my question.
Thanks for the help guys!
