lacruiser is an unknown quantity at this point
Front Wheel Bearings
Hi folks. I'm having some issue with the proper tightening sequence. I have the FSM, and I understand the procedure. Instead of a spring scale, I used a weight of 10 lbs, and measure at the lug that is at the 3:00 position.
I have installed new Koyo bearings and races. The vehicle is a 1991 80-series. The problem:
When I adjust the inner nut (adjusting nut) to the proper tightness, it's fine. Then when I tighten the outer lock nut to the recommended torque, I notice three things:
First, the bearings tighten up quite a bit, and way past the spec. There is no way the 10 lbs weight will break it loose and start it turning. It requires probably 15 to 20 lbs.
Second, I notice that on the "first" turn of the hub/rotor after the locknut is tightened, it requires a much greater force then on subsequent "starts". IOW, once it's "broken loose" after the locknut is tight, it's looser, but still much tighter than it's supposed to be.
Third, when I put the required force on the lug bolts (each in turn, as the hub is rotated and they each come into the 3:00 position), I notice that some lugs "start" with different amounts of force.
It was suggested to me that I forget this whole sequence and simply tighten the adjusting nut to about 7 ft/lbs and then tighten the locknut to the 65 ft/lbs, and that would be fine. But when I do the adjusting nut at 7, it's fine, and when I do the locknut at 65, it's way tighter.
So, I played around with it and ended up tightening the adj nut hand-tight, then torqued the locknut to 65 ft lbs. This seems to be OK, but I still get the unevenness I mentioned above.
I am wondering what all you folks do, and does it sound like I should be doing something differently?
thanks
Dana
thanks
Dana
