Front suspension clicking.
SOCAL
I found the answer to my own question but figured I might share to help others avoid my near misfortune.
A few months ago I installed new LCA bushings and about a month ago I noticed a click on acceleration and decal. I did briefly inspect my LCA's but they looked tight and I remembered torquing them to ridiculous torque specs. Fast forward to today when I just got home from a 100mi round trip overland off road adventure. I'm washing my cruiser and I figure I will hit the undercarriage with the pressure washer and look what I find! Jeez, that could have gone sideways fast!
How do I prevent this? I remember torquing them to some where in the 180 range which i believe is FSM spec. Should i go more? Should I use blue loctite? Also fo my one missing nut? Can I use a standard shape nut of the appropriate grade? Should I use a nylok? Also could anyone please save me some time and tell me the thread pitch?
Thank you,
Skip
The bolts are supposed to be one time use. That being said I know most don't follow that.
You have a couple of things going on here. The flange is bent and needs to be bent back. Also make sure the bolts are installed from the outside in on the frame side as well.
Heres the torque from the manual. It shows 127ft lbs with the full weight of the vehicle on the arms.
also included where it shows its a non-reusable part.
Glad no one was injured!
Edit: looks like you saw the 172 NM torque setting not FT LB
Notice there is no torque spec on the nut, don't torque the nut, torque the bolt. The nut has splines or ridges on it to hold it in place. You torque the nut you strip them off.
Cheers
thanks for the help guys. I have decided that I'm going to get some new factory nuts and bolts. They are so reasonable in price it does not make sense to get random nuts and bolts. I think between getting new nuts with ridges, and torquing them properly that I should be good. I am also going to mark them with a paint stripe and check them regularly. here is a schematic with the part numbers if anyone ever comes across this and wants to order new parts.
front-axle-arm-png.956219
