Front Suspension binding question
Richmond Va
J lift with caster plates, heavy truck
I have suspension binding when I drop the truck in a ditch or off a rock, when the front suspension compresses it feels like my bump stops are hitting my springs, at least that’s how it sounds, it’s a large ping
What is my solution, is there and adjustment or mod on the bump stops?
Second pic shows a shiny spot where the bump stops are dragging the springs.
Maybe caster plates, maybe bent control arms, maybe collapsed spring, maybe bad bushings in the panhard bar, maybe bad bushings in the control arms.......
Root cause is most likely lifting the rig and not lengthening/moving the radius arms. As you lift, the axle moves backwards (rotating around the radius arm chassis mount).
You can see where the bumpstop is contact the axle, a bit forward of where it should. The missing dust should be centered on that pad on the axle.
Looking at it again, I agree.
It looks like the solution is longer arms, with that I would get a solid contact patch for the bumps and no binding.
I’ll look into longer arms, thank you for your help
Of course!
Do you have spaces under the OEM bump stops? Local guy was making a spacer kit that mounted inside the coil on the axle perch, instead of dropping the bump stops from the top. Solved the problem for a bunch of us.
This is common on trucks with Slee/Metal Tech/etc caster plates. Plates of this style rotate the axle backwards to achieve the caster needed instead of moving the entire axle like the Land Tank ones or the washer mod. On trucks running 37s, they also start to rub on the rear of the wheel well. Radius arms which move the axle forward are an option, but so is better caster correction.
I have the Slee bump stop drop, when I called Slee for advice they mentioned I can trim the lip for the bump stop, I’m going to see if that helps. I definitely see where longer arms are needed.
Besides the j springs and shocks my whole lift kit is the slee 4”. I’m very happy with how it drives, it sucks I have this small issue.
Does the spacer your talking about adjust the angle of the bumpstop, that would be the best solution besides new arms
