Front shock threads after oem spacer install.
Socal
Does anyone have a photo of how much threads are left on the front shock top hat studs after installing the oem 10mm spacer? I am thinking of installing it on my Dobinsons set up but only have about 10mm of exposed thread on the studs on the top hat. My Dobinsons suspension came fully assemble so it is not the factory top hat/studs. Curious if stock suspension is the same.
Thanks ckkone. Did you use the factory top hat with the TD struts? Looks like the 4 nuts are flush with the studs?
