Front main bearing
Barrington, RI
I am rebuilding my 1977 FJ40 2F engine and can not remove the front most main bearing cap. I have removed the 4 bolts I am sure of but it still does not drop. What am I missing?
Also, is there an easy way to remove the crankshat end plate where the timing gears are so that I can replace the gasket?
Thanks in advance,
John
You answered your own question. Yes there are bolts from the timing cover that go into the front bearing saddle. You have to deal with the timing cover first.
As stated, been there done that. Cover is off. I don't see another mystery bolt.
How many bolts should be removed? More than the 4 I have removed?
Do i have to remove timing gears?(say No please).
Thanks again,
John
