front locker motor crack
Wandering the Western Hemisphere
Website
www.expeditionamericas.com
So as I continue the prep for my trip I, with considerable help from my friends, managed to get a lot accomplished the last 5 days. Tcase seals, upper oil pan and oil pump cover sealed, new blue nose fan clutch, re-build the rear calipers, clean up my dual battery setup (wires were too long) clean the radiator and flush all the fluids. the biggest task on the plate was the 4.88s. got the axles torn down in about an hour. diffs took pretty much all day saturday, during reassembly on saturday night we came across a serious problem...
that is the shaft for the front locker motor. my pinion had been covered in 90W for the last 6 months or so. i thought it was a leaking pinion seal but now i know the o-ring on the motor could not seal and thus dump out fluid. locker still worked but was hemorrhaging fluid. you can see here where the shaft cracked...
it took a few days to get the motor in and damn was it pricey but now the truck is back together and running. i love the way the truck drives with the new gears. the rest of changes are paying dividends as well. no leaks coming from under the truck and it seems to be running a few degrees cooler as well. i need to put a serious load on it to see if i can get the temps up but with the new clutch, cleaned radiator and gears to move the truck I think i should be just fine.
i almost feel bad putting this shiny new motor on my filthy truck.
and the final product...
if you find yourself constantly wiping gear oil off your front diff and can't find the source, pull the locker motor and give this a look. the downside to the fix is that it doesn't come cheap. a local dealership is sponsoring my trip so i got the part for a smokin deal and still paid $350, retail is $500+
dmc
Which one of your vehicles are you using this on? Would a Cable Locker conversion have been a remedy?
I guess I need update my signature. Both 40s are gone. This was in the 80. A cable may have been a good fit but with the limited time I have and the truck on jack stands in a friend's garage for 5 days I couldn't explore that solution.
dmc
Continuing thread hi-jack...
Wow Dave. Badass adventure. I'm as jealous as the rest of us here for sure.
You have a rough schedule or a rough course-map layed out? I'll be flying down south a couple times around the first of the year. Be cool to meet up with ya if times and places matched up at all...
-Ferg-
more appropriate threads here and here however this thread was created primarily for future searches on a cracked motor so let's continue the hijack.
i have a very rough agenda planned out. only 2 firm dates as of now. One to pick up a friend in Cancun, one to drop him off in Costa Rica. the goal is to get to Ushuaia by the end of March at the latest then i'm open after that. once I arrive in VZ and get a feel for the pace of things i'll work out a tidier agenda from there.
dmc
man i'm jealous. That looks like fun...i would need to learn spanish though. :cool:
i will be watching your blog and pics. don't forget your BOM.
i don't know spanish but man are the learning cds enthralling to listen to. i'm getting there but it will be a baptism by fire once i hit guatemala i'm sure. speaking of which, no BOMs for this trip, but i do have a list of buildings along my entire route. figure i could spend a night or two in parking lot.
dmc
