Front knuckle question
I'm going to open the inspection port tonight to see whats up. Any tips on the best method to do this or measure levels? Figure if it comes up soupy I'm hosed anyway and I will just tear it apart.
Making sure that we are using correct terminology.
The liquid placed in the center differential is OIL, not grease.
The gray looking stuff placed in the outer knuckles is GREASE.
The stuff dripping off the knuckle is which?
The ball on the knuckle SHOULD have a coating of GREASE slimed on it, however, not enough to "drip" onto the tire.
Something else that was not mentioned and I have had this happen to mine.
Make sure you clean the axle housing vent line. 60" of 1/4" fuel hose, a 1/4" fuel filter and 3-4 hose clamps to fit will solve that problem as long as you confirm all parts are clean.
I have rebuilt my front axle with all new parts (new axles, bearings, seals, etc). Within 5000 miles, my RF knuckle was leaking and I had moly grease contamination into my gear oil. This indicated a axle seal failure and since I had all new parts, I refused to believe I screwed it up.
I drained the oil from the housing, sucked out the contaminated oil/grease from the ball, and refilled both appropriately.
I then removed the axle housing vent fitting from the housing (it unscrews) and I had to use a parts washer and a pick to to get the gunk out of the fitting AS WELL AS the hole in the housing. The gear oil in mine had solidified in the fitting and housing and it was so hard I had to scrape at it with dental picks to get it out.
I reinstalled the fitting, installed the 60" of hose and filter (up by the brake booster) and tried it again. My problem went away. Make sure you keep the filter in the VERTICAL part of the hose so it a bubble of gear oil burps up the hose, it will tend to drain back down while it sits.
This all happens because the housing heats up on long drives and if the pressure cannot be relieved, it will push gear oil past the seals. Then, as it cools back down, it goes to a vacuum state and sucks in the gear oil / moly grease combo from the knuckle and contaminates the gear oil.
It's not the end of the world, but it is solvable.
I've now been driving another 45K miles and have not had a repeat of the issue.
Good Luck!
Good Luck!
Yeah, It was grease as far as I can tell, not differential oil. I will pull the vent lines to make sure they are clear as well. Wouldn't think this would be an issue as it's hasn't really been off road. I will run the zip tie in and see whats up.
I do very little off-road. It's the highway speeds that heat it up. Then you stop and let it cool down and it cycles the other way. I'm originally from NW Iowa, so I understand the heat/cool cycles well.
Should be able to get some idea by looking at the ball and wipers, a grease line forms at roughly where the level is. When the plug is opened, there is often a grease skin that needs to be cleared. Some use a zip-tie, but often gets grease all over it from touching stuff, making a true level difficult to determine. I just look in with a flashlight, needs to be 1/2-3/4 full, so should be able to see the grease level, if not, the ABS ring looks dry, spindle bushing is exposed, it needs grease.
The knuckles doesn't have a breather, so needs air space, not totally full. Getting the level correct often isn't a one time deal, if it's really low, add ~1/2 tube, drive it for a while, recheck, if still low, add 1/4 tube, repeat, until it's correct.
Depending on the grease, some gives up it's oil pretty easily. The lower knuckle to arm isn't sealed, so somewhat normal to get some seepage. It's good to confirm torque in those nuts, 71ft/lb. It's also somewhat normal to burp slight gear oil past the axle seal, if the grease level is correct, will absorb, mix it in, if low, not so much.
Good Luck!
@BILT4ME - that’s a great explanation, and I can confirm everything you say as I have had the exact same thing happen to me. Thanks for sharing :clap:
I’m in the process now of cycling several drain/refills of inexpensive Walmart super tech 80w90 to get some of the moly grease out of the front diff. Although I replaced the stock diff breather as described above, that moly/oil mix is some thick stuff, which can make “breathing” a bit more challenging. So, a clean diff breather and some mouthwash for the diff should set everything straight.
I didn’t take any picks but the knuckles after checking seem to be just under half full with grease. It doesn’t seem like any oil is present that I can tell, thicker and viscous not soupy like when I did the knuckle job. I used a moly grease but I don’t know how good it actually was, Mystic was the brand from Mills Fleet. I used Lucas oil for the bearings so I’m kicking myself for not looking around a little more. I searched and saw people are adding grease around 5000 miles or so and I’m there now. What’s the easiest way to get it in through the check port? Cut the corner off a plastic bag or grease gun? On a side note, needs the power steering lines and pump replaced and oil on the passenger side seems like it’s making its way down from the valve cover gasket. More fun coming up!!!
Grease gun.
I'd clean and look closely at the hoses, before I replaced them. I just went through this with Malleus the Younger's 80. His pump was leaking from the rear and it looked like it was coming from everywhere. Vato Zone came through with a Ø5/8" hose for the reservior, which fit well enough that the clamp is holding it. The Ø3/8" hose from the cooler was another story entirely. DO NOT touch that hose if you don't have to. His fell apart when I pried it from the tubing at the reservior (as did the larger drain hose). Having done what I did, I would not repalce either of the low pressure hoses unless a) I had to, or b) had OEM replacements in hand, or both. The cooler tubing is thinwalled mystery metal and you can't lean on it hard enough to properly seat the smaller ID hose. (I got it on, but I'm not happy with it, and it's not my truck)
The Ø10mm tubing is far to small to comfortably slide a Ø3/8" thickwalled ATF service-rated hose onto, and the hose is part of the cooler. I have yet to find metric hydraulic hose anywhere.
The pressure hose isn't likely to need replacing unless you've cut it somehow.
Grease gun.
I couldn't tell for sure. The high pressure lines had fluid on them but not sure where it's coming from. Pump had a leak from the rear when I bought it. I have a rebuilt OEM pump ready to go along with some aftermarket high pressure lines. The paper clip is rusty so I was going to switch that out with a derale cooler and run Wit's end lines in place of the oem metal lines through the frame. Just waiting for nicer weather to move on it.
Ill pick up a grease gun this afternoon and run some in there. Thanks for you help on this!!
FWIW, the rebuilt pump doesn't come with a gear. You have to remove the gear from your pump and install it on the new one. The gear teeth are not hardened. (This is intentional, because the pump is driven off of the engine side gear, which is hardened. When something rubs a hard surface it has to wear or the hard surface will fail.) I used aluminum shims when I removed mine and still dinged them. Fortunately, the damage was on the coast side of the gear, so I just hand-hobbed the profile.
A three-jawed puller is better than a two-jawed one for this job. Take your time removing/installing the gear. If you can put bearing pressure near the hub/shaft, that's better than pressing against the teeth (I couldn't). I had to use a 24-in cheater bar to remove the nut, too.
FWIW, I bought a $10 Harbor Freight Grease Gun and dedicated it to the Valvoline Palladium grease that I use in my Birf's (I also use it for the suspension on my Studebaker) Works great for what I need! I bought the one-handed pump squeeze grip kind, not the long action lever type. But it IS a full size tube style.
