Front inner fender wells.
PA
Anyone replace their inner fender wells? Mine have some pretty decent rust holes and I thinking of replacing them. The problem is, it looks like a real PITA. Just wonder the time involved in doing it. Thanks
It's not so bad. Worst part is likely cutting through the seam sealer between inner and outer. There's a great description on here that would probably come up under inner fender search but I just went at it pulling bolts and kept looking till they were all out. A couple hiding behind the corner lamps I believe, the valance up front has two in each side bolted to outers I believe, and the tricky ones are two at bottom back side that may require dropping slider if you have them and one in the door jamb that requires opening front doors to access 3-4 hours should be sufficient. The driver side has way more crap bolted to it.
@jfz80 is on point. Mine had prior body work so maybe the seam sealer was easier to deal with.. but that wasn't a problem for me. Bigger issue is some of the female fender clips that the 10mm head bolts go into between the inner and outer fender had their plastic retainers cracked and this allowed the nuts to spin behind the fender. Real pain in the butt to dislocate my wrist/elbow/shoulder to get at the rear ones with a pair of vise grips for backup. If I were you I'd order at least a few of these and have them on-hand when you go to do the swap.
Beyond that.. find a good combination of extensions and universals to get at the four 12mm bolts that attach the rear of the upper inner fender to the firewall. Those things are buried in there.
Did make any progress on this yet?
I just pulled the fenders off my wrecked '95 last night. I wasn't too worried about damage, but second everything already said. The plastic bits are old and cracked. I had at least 3 break. I had 2 rusty heads break off. If I was worried about damage to the fender it would have been much harder to resolve. It didn't take long to remove the outer fender. Don't forget you have to lift the cowl to access a bolt. I removed the hood to make it easier. Remove the DS wiper arm and lift the cowl a bit to get at it on both sides. I think it's a 13MM to remove the wiper arm. I used a crescent wrench and a lot of care. LOTS of stuff mounted on the DS inner fender. A flexhead ratcheting box wrench, 10MM and 12MM, will be your friend. But, yeah. Probably not more than 4 hours or so.
Yes, drivers side looks horrible.
