Front heater installation
Leesburg, VA
Bought an OEM heater from cp.net cleaned it up...looks nice....but need some help with the installation. I did a search on the site....but I am looking for a nice breakdown with digram...etc... anyone.. This is a Southamerican FJ...so it never had a heater....and there are no others in my town to look at as a go by..
thanks.....
if you post up some pics it would help people guide you.
Cabron.....I am from Madisonville, KY.....just west of you. My FJ is in KY....and I am in Iraq... Was just looking for diagrams or pics of other installations to gather before I go home on RR in April...
hopefully but doubtffull, you will have the captive bolts on the firewall, if so then its just a bolt up for the heater unit. But I suspect it wont have them, same with the blower, the PS duct ect. might be easier to move someplace warm ;)
Maybe we can grab a beer when you get back. I would just check when you get home to see if there are any existing hole/bolts that might facilitate an easy install. PM me if you need any help w/ anything
I think what Pimp meant is 'captive nuts' but he just didn't have the balls to say it!;p
At any rate, I think that you'd be FAR FAR ahead of the game to go with an aftermarket heater, even tho stock looks cool and you've got stock. Stock is gonna require a LOT of fabbing to work.
If you're gonna go stock all the way, you're gonna have to cut a MASSIVE hole in the firewall for the stock heater fan motor to blow thru [yes Pimp I used blow and nuts in the same post!;p ]
Then there's the fact that you may not even have defroster vents set up in your dashboard to get the air up to the windshield frame. The windshield in my 64 lwb came from a non-heater cruiser and the PO did a really @&@&@&@&ty job of making the cutouts for the defrosters. One day I'm gonna pull the windshield frame out and either do it over or weld the whole thing shut! It's one of the fugliest parts on the truck.
If you go with an aftermarket heater, they generally come with an integrated fan motor, which 'cleans' up the installation considerably.
Good luck
Mark
nuts......bolts whatever :flipoff2:
and I think Mark makes some very good points, its gonna be alot of work going OEM in this case.
I think some of the mini trucks used a heater with a fan built in, that might be an option if you want sorta OEM
Good luck
Mark
The nuts might not be there, and it's a little hard to see in your last pic, but it looks like the holes are there for you heater box. The heater hoses go through the firewall by that little black box that's just up and foward of the trans. tunnel on the passenger side, you can see that in your last pic also. Go to SOR.com, I bet there's a good pic and breakdown of parts for the heater hose assy.
