Front Heat?
Minnesota
bump.
What is a power flush?
Have you bled the system for possible air pockets?
I believe a power flush is when you take it to the shop and they hook it up to a machine and use somekind of pressure to drain and fill the system. But don't quote me.
No, I haven't bled the system yet. I didn't think that there could be air pockets. I guess I've never had any kind of air pocket issues. How do you bleed a coolant system?
Its possible there could be an air pocket in the system.
It also could be the main heater core.
See the red arrow, that points at the valve for the heater.
I had the same problem in my truck. I got me some spray lube and lubed the wire inside the cable that runs trough the firewall.
You can easally plug the cable off the valve and turn the it to see if it is stuck or not moving like it should.
Insinde the car there is a servo motor that turns the valve, before connecting the wire to the valve check if the motor is working by turning the heat up and down and see if the wire moves in and out.
I have also seen a bad solder inside the heater control wich led to the same problem.
Make sure your recirculate switch and your defrost in the AC panel are NOT pressed in the outside air position.
Check the temperature of your heater hoses where they go into the firewall, if one is significantly hotter you probably have a clogged heater core.
You don't need a thermometer to do this, just your hand.
I honestly don't know how a power flush would happen but from understanding the coolant system you would have to open up the thermostat for the flow of liquid (whether that means taking it out or opening the thermo up under it's normal operating temps) and open the valve that operates the heater core as well.
Like Hondaguy said, check the hose that comes from the valve (pictured above) going into the firewall. If it's not that hot then check that the cable that's coming from the firewall to the valve is connected to the valve. That's your temp on the console.
You can take the cable off and move the arm back and forth thats on the valve. If you have good resistant to moving the arm then the valve should be okay. If everything checks out then something else is a mist.
Why did you not replace the water pump?
So,
It's getting really cold in Minnesota. My front heater isn't getting hot enough. It's just warm. My rear heater is hotter than the front. Is this normal?
I've replaced my thermostat, radiator, replaced coolant.
Could my front heater core be plugged? Would anyone recommend a power flush?
Any ideas?
I would say your front heater core is plugged, but not completely if you're getting some heat out of it. Heat valve that haffi in post # 7 is referring to controls hot water to both front and rear systems, so if one is putting out less heat, it is not the valve. I like hondaguy's idea to check hose temps with your hand, but heater output is real test. You can disco both front heater hoses and flush out just the heater core, but if you use too much pressure and rupture heater core, you'll have a mess in your rig, so proceed with caution.
This happened to me this time last year. I flushed out my heater core as 80t0ylc describes and have been good to go since. A lot of crud came out and I plan on replacing the core at some point. It doesn't get as hot as the rear heat but well enough to keep you warm and defrost. I'd give that a shot.
I've got a similiar prob - no front heat but plenty of back heat. Strangely this happened after a new battery was installed...
The heater control cable is jammed and won't move - but when I manually open the valve I still only get back heat... Any possible connection to the new battery or just coincidence? What's the location of the servo motor inside the car that controls the heat valve in the engine compartment?
Sounds like a coincidence to me, to me. Past the heater valve/temperature control you basically have 2 independant heater systems. If your heater temperature control is successfully controlling at least one of them, it's working fine. If one is not working, the problem is in that system. Also, your ignition must be on for your heater valve to open/close with dash slide switch. For the location of servo motor, follow cable from valve through firewall.
BTW welcome to mud!
Thanks 80t0ylc - I'm working my way through that front heating system now. I have been troubleshooting the system with the ignition on but you mentioning that may have just given me a tip to an electrical gremlin I've been chasing - I'm sure I'll be posting about that one shortly...
