Front factory locker does not work after re-install.....
Winston Salem, NC
I have a 1996 LC, factory lockers. I just rebuilt the front axle (and the rear), re geared, etc. I have installed the front locker which worked before I took it out. The locker was UNLOCKED upon removal. I followed some directions on how to re-install that I found here. I believe the locker is mechanically locked as the outer tooth on the actuator is centered over the hole in the diff. I lined the marks up on the locker 'pinion' gear as it was shown in the instructions (up and down orientation), installed the locker and it is not working. The dash lights show that it is locked no matter what position the locker dial is set to. It is solid red, not flashing. On a side note, I dont know if this may have screwed something up, I also did the Part Time conversion, added a CDL switch out of a 4runner (not sure if it works) and did the 7 pin mod. My Part time is not working either (stays in 4x4), but that will be for another thread. I am sure I have this installed incorrectly, any hints, tips or ideas??
I can't give you the expert, efficient guide to fixing this but I've had my locker in and out a few times and have run into the same issue. For me, pulling the locker and some combination of actuating the locker while it's not mounted on the diff (but is plugged in) and moving the locker plunger in or out (can move it through the hole that the locker drive gear goes into) has helped me get it back into phase and working. You can lift one front wheel and keep playing with it until you are confident that it is locking and unlocking properly then install the actuator and do a final torque down. A few tries of the plunger and motor and you should get it back in synch.
Hope that helps,
When switched, does the actuator motor run? When installed was it properly timed, both the actuator and locker in the lock position?
If it was UNlocked when removed, then my best guess is that it was installed when locked. The actuator is still unlocked, the diff is locked, and neither one wants to move. :)
I thought it had to be locked to even get it out??
The locker is in the mechanically locked position. The locker motor is not in the same position as when I took it out, I attempted to time the locker before installing as shown in some instructions....
