Front end problems - rough pulsating when turning hard
Florida
Although I have had my FJ80 for 10 years, it has essentially been in storage with very little driving. It will soon be my daily driver, so I am preparing to do a lot of PM. I have almost zero mechanic experience but have learned so much just researching this forum.
First to correct is a hard "knocking" or hard pulsating of the steering wheel has when I make a hard turn (left or right). It almost feels as though something in the steering assembly is refusing to become engaged. This problem arose after I recently replaced the steering stabilizer with an OME. The OME does not line up exactly like a OEM part - it is under more tension than the stock stabilizer. But I have not read of anyone having such problems with an OME stablizer, so I am thinking it must be something else.
Any suggestions? Thanks in advance...
Since the problem started when you put it on, how about taking it off and seeing how it feels?
That is a direct bolt on. Please explain what you mean.
Sorry for the late response...computer issues.
The OME stabilizer has fixed pins while the OEM has a pivoting pin. To install we removed the bracket and fitted it to the shock first, then "torqued" the shock into place while reinstalling the bracket. We followed Cdan's post https://forum.ih8mud.com/80-series-tech/90760-steering-shock-observations.html. So the OME stabilizer is "torqued" compared to the OEM. Maybe we missed something?:confused:
coolbreeze - Seeing how the steering feels after removing the stabilizer is a good idea. I will try that this weekend.
