I'll preface this by saying yes, I did search.
I'm currently battling a front end noise on my '97 and wanted some input. I've dealt with the classical front end GRRR's and can say with confidence, this is a different noise.
Forgive the length of my post, but I'll try and be as detailed as possible.
Truck facts: '97 LX450. 135k miles. OME medium springs all around. OME Yellow front bushing. Weight wise, the truck is stock with the exception of duals in the front and a cargo storage platform.
The noise is consistent and grows exponentially with speed. Feathering the gas pedal does NOT affect noise at all.
It becomes apparent at say 20-25 mph and get louder with speed. As far as what it sounds like, its similar to the GRRR but not the same. I've had trucks with the classical GRRR noises and those problems were all front DS related.
The first time this noise came about I check the diff gear oil and it was low, added some and the noise seemed to go away for a week or two. This week the noise reappeared. It is prevelent when going straight or turning to the left, but NOT when turning to the right! ODD.
This afternoon I removed the front driveshaft, locked the CDL, and took it for a spin. Noise remains and is relatively unchanged. I also added a small amount of 85W-140 gear oil to see if thickening it up would make a difference, it didn't.
I've ordered all my parts for the front end rebuild and plan to do that next week before I leave on a cross country trip. I did not however order wheel bearings as the truck only has 135k miles but will most likely try and get some for good measure.
Any ideas or opinions?
My gut is that the sound is coming from the ring and pinion but cannot imagine why this would come overnight, I'm hoping its not as this would require a more involved repair.
Thanks.
Thanks.
