Front End Groan
North Front Range, CO
Just before I stop I here a groan from the right front tire.
That is the only time I here it, it lasts about a second. It happens if I use the brakes or not.
The wheel it tight.
I am running XTerrains.
What does a wheel bearing sound like when its bad and when does it make noise?
This is the wheel I have been having problems with when I adjust the wheel bearings. I checked the bearings and they look good and are tight.
I first noticed the noise when I put on the tires.
The bearing could make the noise and still feel tight. You may need to pull them out and check for pitting.
Might be the spindle bushing howling at you 'cause it wants more grease.
-B-
I also need to add that there is a poping noise every once in a while when turning.
Well, after taking apart and rechecking the wheel bearings, removing the rotted and falling off heat shields that go on the exhaust pipes before the cat, rotating the tyres, I FOUND THE PROBLEM:cool:
The stablelizer to linking arm bracket broke.
The bracket is welded to the linking arm. There is a hole in the bracker and the linking arm.
Can I just put a bolt in the hole or will I need to weld it?
I smell a sale in the very near future :D
