I had really nasty shimmies in the steering wheel under hard braking while descending some mountain roads this weekend - most pronounced from 60-mph down to 30-mph. Brake rotors are fairly new (~20K miles Brembos) and have had 100-series pads since new (new pads ~10K miles ago), new calipers installed last weekend and the week before that had the entire front end rebuilt. Have checked torque spec on wheel bearing lock nuts, have rotated tires and had them balanced. Still getting this shake. I'm assuming now that it must lie in the steering. Maybe bad/worn TREs? Truck has 136K and they're probably the original ones but was looking for someone with experience with ones that are shot having the same symptoms. Steering stabilizer is an OME with about 50K miles on it. Lastly if it is an issue this is occuring with the truck on 285 BFG ATs. Oh, yeah it also has the OME caster correction bushings and it is "almost" there - still need to try the IFS weld in adjusters...
Any thoughts where I should start?
Thanks.
Mike R.
Thanks.
Mike R.
