Front DS ? Zirk direction
Which direction do your front DS zirks face?
  • zirks on opposite sides
    Votes: 0 0.0%
  • I have a huge lift and a double caridan DS
    Votes: 0 0.0%
  • Total voters
    2
Southern WI
So I found out my front DS was all out of wack. 8 years ago I had a shop put new U-joints in and balance the drive shafts. They put the front DS back in, in phase, so they probably never even balanced it. Regardless, they put it in wrong. Now, I have my front DS back in, and exactly 90 degrees out of phase, but it may still be wrong. So i'm wondering, which way do your zirks face on your front DS? Are they on the same side, or opposite? I know, I know, but for most you this will be easy, all you have to do is lay down on your back.
IIRC there's only one way for them to go in so you can access all 3. If you put it in backwards, you won't be able to reach one zirk. (I mean literally, not just turn the DS.)
And yes, it's easy to look at, but it's dark! And wet! And cold!
The FSM has a detailed diagram showing their exact orientation. They are all on the same side of the shaft, but there is more to it than that in terms of which one is pointing which way. The details won't matter to answer your question if you are sure that the U joints were installed properly in the first place.
