Front Driveshaft Flange
San Diego
I am diagnosing a vibration and am in process of removing my front drive shaft. I have all the hardware off on both sides of the driveshaft. Front flange at diff is off, the end attached to the transferase is giving me a bit of grief. On the diff side the small ( collar?) that centers the flange to the 3rd member was a bit hard to remove( probably should have a slight smear of grease at reinstall?). Is there a collar to center the transfercase side of the shaft to the tc flange? It seems like a bit of pry bar pressure could be the solution, or is there something I missed. I definitely haven't and don't want to bang on these components. I read all the posts in 80-Series tech and none of them addressed this specifically. I'm headed to Freight for a set of pry bars before they close
Common for the flange to be a bit sticky. Tap it with a hammer, bump the driveshaft against the limits of ujoint deflection and or use a pry bar.
Mark...
Thanks I got it out. Joints and pilot were definitely in need of service. The surface is the pilot to transferase was lightly rusted together. PB blaster overnight did it. Looks like I'm going to get a double cardan driveshaft. thanks for the responses
