Front drive shaft
miami, fl
Have a vibration during acceleration so I took it to the Lexus dealer .
I was initially told that it was the u joint that needed to be replaced but that would be checked the next day with the shop foreman
They called me this morning and told me that the whole assembly had to be replaced what are your thoughts
Remove it, lock the center and see for yourself.
The dealer hasn't given you (or us) enough information to go on. I would make them explain (and show you) why the entire drive shaft needs to be replaced rather than just the u-joint.
I had an experience like that with a Toyota dealer. All they know is to swap parts instead of fixing them.
Like the guys say, pull the drive shaft, test for yourself and send to a driveshaft shaft to check for straightness, balance and replace u joints if necessary.
When they say assembly, what exactly are they referring to? Your sig shows you have OME suspension...how much lift do you have? Have you pulled the front and rear drive-shafts independently, locked the center diff and tested to see if vibration go away with one shaft removed? what are your operating angles of your drive shafts, if running stock shafts (non DC), the flanges on diff and xfer case should be as close to 0 degs difference as possible.
lots of possibilities, as others have said, need more info to help give you solid advice. Very unlikely that you would need to replace the rear shaft...you would have had to have been smashing it on rocks. If its the front shaft, then there are options.. Double Cardone / Cut & Turn et.
