front drive shaft ????
in the garage
'97 80
should be ok to remove the front drive shaft for a couple day to get u-joints put in right?
as long as all the flanges are marked and go back in the way they can out.
just want to make sure. my buddys 80 has a bad front joint that is vibrating like made and can't get to replacing them till tuesday.
comfirmation on this please.
thank
jim
It's OK as long as you can lock the center diff lock. If you don't have a center diff lock switch, you shouldn't do it.
Yes, he can drive it without the front DS as long as the center differential is locked. If he is not equipped with the CDL switch, then he can lock the center differential by:
1. Shift the t-case to L, this will lock the center differential assuming he has no problem in that area.
2. Pull the differential fuse (left knee area while sitting in driver seat).
3. Shift the t-case back to H, the center differential should remain locked.
It doesn't, but the unlocked centre diff will supply power to whichever side (front or back) has less resistance, just like an open diff in an axle.
